Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Truck
Engine
Symptoms
Runs Rough
1993 Chevy Truck runs rough at low speeds
1993 CHEVROLET TRUCK
200,000 MILES • V8 • 4WD • AUTOMATIC
BLAZER1979
MEMBER
FOLLOW
starts and idles fine but when the throttle is depressed slightly runs rough and wants to stall did a tune up about 3 weeks ago
Aug 10, 2009 at 2:10 PM
DOCFIXIT
CERTIFIED EXPERT
Was it stalling before tune? if yes check fuel pressure
Aug 10, 2009 at 2:18 PM
BLAZER1979
MEMBER
just started three days ago
Aug 10, 2009 at 3:09 PM
DOCFIXIT
CERTIFIED EXPERT
Check fuel pressure 55-61 psi also maybe faulty MAP sensor
Aug 10, 2009 at 3:14 PM
BLAZER1979
MEMBER
new pump and filter about 3 months ago checking map now
Aug 10, 2009 at 3:39 PM
BLAZER1979
MEMBER
unplugged map (at least i think it was) and truck ran great
Aug 10, 2009 at 4:11 PM
DOCFIXIT
CERTIFIED EXPERT
If it was on right valve cover to the rear and had a hose attached that's it. And pulling hose it runs good is the test. Extra desert for you tonight
Aug 10, 2009 at 4:18 PM
BLAZER1979
MEMBER
it was in the middle with two hoses
Aug 10, 2009 at 4:34 PM
DOCFIXIT
CERTIFIED EXPERT
Does it have three wires? see diagram
Aug 11, 2009 at 8:29 AM
BLAZER1979
MEMBER
not sure how many wires but hose comes from the egr valve the other goes to the back of the throttle body
Aug 11, 2009 at 11:00 AM
DOCFIXIT
CERTIFIED EXPERT
That is EGR solenoid so it must be opening EGR at idle stalling engine.
Aug 11, 2009 at 11:11 AM
BLAZER1979
MEMBER
is that what i need to replace is the silonoid
Aug 11, 2009 at 11:23 AM
