1993 Chevy Truck front axle not ingaging
1993 CHEVROLET TRUCK
133,000 MILES • V8 • 4WD • AUTOMATIC
ROB BENNETT
When I put the truck in 4wd the front axle does not ingage,and the indicator light does not come on. I have replaced the 4wd actuator with a brand new one,and checked the fuse under the dash, it is good.What else can it be?
Mar 15, 2008 at 4:35 PM
MASTERTECHTIM
  • 4,750 POSTS
did you check for power and ground at actuator? just run a test light across the 2 terminals and get back to me.
Mar 15, 2008 at 4:38 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Not so much a head gasket, but if seriously over full you could experience seal failure, as the crank case pressure could rise due to the excess oil level a leak could occur, but just a a little overfull should not be an issue.
Mark (mhpautos)
Apr 3, 2008 at 4:32 AM
