1993 Chevy Truck Chevrolet 1500 Truck - Coolant Leak
1993 CHEVROLET TRUCK
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
OKCMANN
I have a '93 chevy 1500 truck, 6 cyl, that has a coolant leak. It looks like its coming from the bottom of the cover for the timing chain. I've replaced the water pump, thermostat & hoses & not leaking from them. Can anyone help me? Thanks
Oct 26, 2008 at 3:43 PM
JAMES W.
  • 2,394 POSTS
If your waterpump mounts on the timing cover then I would suspect the gasket between the block and the timing cover.
Oct 28, 2008 at 6:22 AM
OKCMANN
I'm going to pull the crankshaft damper to get to the timing chain cover & see if thats it.
[quote:f6a37ef66e="James R. Weizel"]If your waterpump mounts on the timing cover then I would suspect the gasket between the block and the timing cover.[/quote:f6a37ef66e]
Oct 28, 2008 at 7:56 AM
