1993 Chevy Truck Bad fuel pump?
1993 CHEVROLET TRUCK
200,000 MILES • V8 • 4WD • AUTOMATIC
CORY GRABEEL
I was driving down the road and my truck just bogged down, I was going about 60 mph, i made it about 4 miles. I could barely keep it running and then it totally died. it turns over but won't start, I dumped a little fuel down the carb and it started but would,nt run. how can I check the fuses before I pull the bed off the truck to replace the fuel pump?
1-27-08 I replaced the fuel pump and it fired right up and runs great, I found the easiest way to do this was remove the bed , we dropped the tank first but there wasn,t much room , so we tool out 8 bolts and unhooked the wiring harnest lifted the bed off with a small hoist a nd were done in about an hour.
Jan 25, 2008 at 4:05 PM
MOUNTAINDAN
  • 6 POSTS
You may want to check the fuel filter before you go much further. I would also pull the input line to the filter and put it into a can and turn the key on to see if the pump is working.
Just my 2 cents worth.
Jan 27, 2008 at 8:56 AM
