1993 Chevy Truck BACK FIRES THROUGH EXHAUST
1993 CHEVROLET TRUCK
BILLYB11968
Engine Mechanical problem
1993 Chevy Truck V8 Four Wheel Drive 153000 miles
HI I HAVE A 1993 CHEVY PICKUP WITH A 350 V8 ENGINE IT JUST STARTED ACTING UP TODAY IT WOULDNT START SO I TOOK THE IGNITION CONTROL MODULE OUT TO THE PARTS STORE AND THEY TESTED IT AND IT FAILED SO I REPLACED IT WITH A NEW ONE NOW IT FIRES RIGHT UP WITH NO PROBLEM BUT IT SEEMS TO IDLE ROUGH AND WHEN I PUSH THE GAS PEDAL DOWN AND HOLD IT TO WEAR ITS RUNNING AT HIGHER IDLE IT BACK FIRES THROUGH THE EXHAUST ANY IDEAS WHAT THIS WOULD BE THANK YOU
May 9, 2008 at 11:25 PM
Check the ignition timing/double check your firing order and make sure the plug wires are not crossing firing/leaking and fuel pressure
May 9, 2008 at 11:33 PM
