I have a 1992 Chevrolet C1500 V6. For a few days it has been making a slight hissing tap noise on the passenger side of the truck near the exhaust manifold. Originally I thought it was a possible exhaust leak so I was going to let it go until I had a chance to get it checked. Tonight when I pulled into the drive way it started making a really loud noise in the same place. Almost like a back fire noise only constant. POP POP POP. It just keeps going. I popped the hood and started the truck. I noticed a spark plug wire (not distributor side, the engine side of the wire) was not connected to a spark plug and I could see a slight spark coming from in. It would be to the spark plug at the front of the engine. It is dark outside so it was tough to see, but I couldn't find the spark plug it was supposed to go to, to save my life. I just don't see it! Can you explain to me where it is at? And also, do you believe that is the problem? Thank you very much.
Oct 18, 2009 at 9:19 PM
