1992 Chevy Truck I have a '92 C/K Pickup giving a soft code
1992 CHEVROLET TRUCK
197,137 MILES • V8 • 2WD • AUTOMATIC
BMMORGAN71
I have a 1992 C/K Pickup givng a soft code 24, what does this code mean?
Jan 25, 2010 at 4:30 PM
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Circuit
33 Manifold Absolute Pressure Sensor Circuit (High Sig.)
34 Manifold Absolute Pressure Sensor Circuit (Low Sig.)
42 Electronic Spark Timing (EST) Circuit
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 Faulty PROM
54 Fuel Pump Circuit (Low Voltage)
55 ECM Error
Jan 25, 2010 at 4:47 PM
BMMORGAN71
Thank you for the answer, I appreciate it and your time & expertise.
Jan 25, 2010 at 5:48 PM
