My truck runs well sometimes and sometimes it dosen't. The engine light stays on and if it stays on solid without blinking the truck runs fine. The truck will start and run fine sometimes and other times the truck will start and run terribly. It tries to shut down and the only way to keep it running is to feather the gas pedal until it decides to run smooth and the engine light comes on and stays on solid again. I've replaced the injectors and rebuilt the throttle body and regulator. I've replaced the throttle position sensor, oxygen sensor, vehicle speed sensor, distributor cap, ignition control module, distributor rotor, spark plug, spark plug wires and fuel filter. I've ordered a MAP sensor, ECM and IAC valve and will try that unless you can give me some other advice.
Thank You
Wayne A. Shuttleworth
Thank You
Nov 10, 2009 at 9:05 AM
