Sometimes when the truck is shifted into overdrive the transmission won't shift out of drive into overdrive instead the RPMs climb to redline. Other times it will shift back and forth between drive and overdrive very quickly. Also when it shifts between any gear it sometimes shifts hard with a load thud and you can really feel it. This all started all of a sudden a week ago.
The truck is a 1991 Chevy 1/2 ton extended cab truck 4x4 with a 5.7L V8 EFI engine. I do not know what the automatic transmission is or were to look but I am pretty sure it's the factory original.
Any help would be greatly appreciated.
Thanks
Shane
Thanks
Shane
Sep 27, 2009 at 12:02 PM
