1991 Chevy Truck clutch noise
1991 CHEVROLET TRUCK
200,000 MILES • V8 • 4WD • MANUAL
BILLYRAY
I have a 1991 chevy 1500 pickup and i just put a new clutch in it less than a year ago. It was fine up until a few days ago. Now when i push the clutch in when the vehicle is stopped and i let the clutch back out it makes a chattering noise only at first. This only happens once in awhile probably once every 5 times i let the clutch out from a stopped positon. What do you think could be the problem?
Dec 26, 2007 at 8:48 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You may have a defective spring in the clutch plate hub, if so there is not to much that you can do about it, short of replacing the clutch again. I would let it go for a while and if it gets worst maybe look at replacing the clutch.
Mark (mhpautos)
Dec 26, 2007 at 9:02 PM
