1991 Chevrolet Cavalier RS 4DR Electrical System
1991 CHEVROLET TRUCK
CAVALIERDRIVER65
  • 31 POSTS
I own a 1991 Chevrolet Cavalier RS 4 Door. It is a 6 cylinder engine, and the mileage is 190373. I was wondering if you can help me. My cars Battery Light will come on if the engine is up or over 4000 RPM. and my taillights will stay on all the time even if the pedal is not depressed. The mechanic i took it to says its a ground, but my dad tells me that it's my brake light switch thats keeping the brake lights on all the time. i dont know a thing on how to fix this so i came to you guys. can you help me?
Mar 4, 2007 at 9:37 AM
CHEVY22
  • 1,375 POSTS
LETS TACKLE THE BRAKE LIGHTS FIRST AS THEY WILL DRAIN THE BATTERY , YOUR DAD SOUNDS LIKE HES ON THE MONEY WITH THE CRAKE LIGHT SWITCH , THEY ARE CHEAP , LIKE 10-12 BUCKS AND REPLACED IN ABOUT TEN MINUTES , HAVE HIM DO THAT AND GET BACK TO US
Mar 4, 2007 at 12:25 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:a2b8e9e80a="CHEVYII"]LETS TACKLE THE BRAKE LIGHTS FIRST AS THEY WILL DRAIN THE BATTERY , YOUR DAD SOUNDS LIKE HES ON THE MONEY WITH THE CRAKE LIGHT SWITCH , THEY ARE CHEAP , LIKE 10-12 BUCKS AND REPLACED IN ABOUT TEN MINUTES , HAVE HIM DO THAT AND GET BACK TO US[/quote:a2b8e9e80a]
I was more concerned about the battery light coming on at 4000 RPM and over.
Mar 4, 2007 at 2:50 PM
CHEVY22
  • 1,375 POSTS
OK , CHECK BATTERY VOLTAGE
Mar 4, 2007 at 5:58 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote="CavalierDriver65"][quote:dae1c94fc8="CHEVYII"]LETS TACKLE THE BRAKE LIGHTS FIRST AS THEY WILL DRAIN THE BATTERY , YOUR DAD SOUNDS LIKE HES ON THE MONEY WITH THE CRAKE LIGHT SWITCH , THEY ARE CHEAP , LIKE 10-12 BUCKS AND REPLACED IN ABOUT TEN MINUTES , HAVE HIM DO THAT AND GET BACK TO US[/quote:dae1c94fc8]
Ok, I installed the new brake light switch and the taillights are working great now. But is there any different reasons such as grounds that are causing the car to kill itself all the time?
Mar 9, 2007 at 7:49 PM
CHEVY22
  • 1,375 POSTS
it still dies all of the time , ?? how long ?? ask your dad if he knows hoe to do the old school draw test , with a test light and a test light on the b=neg battery cable
Mar 9, 2007 at 10:48 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:54723e093e="CHEVYII"]it still dies all of the time , ?? how long ?? ask your dad if he knows hoe to do the old school draw test , with a test light and a test light on the b=neg battery cable[/quote:54723e093e]
The mechanic i had look at it said to put a wire on a bolt on the engine block and ground it to the body of the car. Could that solve it probably?
p.s sorry to bother you all the time.
Mar 10, 2007 at 6:55 PM
CHEVY22
  • 1,375 POSTS
it is possible especially if there is one missing or burned , and its not a bother , thats why im here but im wondering if something else is drawing off the battery , is anything else staying on
jim
Mar 10, 2007 at 7:10 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:aeb067d667="CHEVYII"]it is possible especially if there is one missing or burned , and its not a bother , thats why im here but im wondering if something else is drawing off the battery , is anything else staying on
jim[/quote:aeb067d667]
If you mean warning lights, no nothing else is staying on. i just don't understand. i'd connect it with another car and it would run like a dream. but once i take off the cables off of my car, it will run for a few seconds, start struggling and then poof, it's dead again.
Mar 11, 2007 at 9:35 AM
CHEVY22
  • 1,375 POSTS
where does the neg cable go , have you checked that yet , make sure it is still on the eng and not broken or corroded , if you have to jump it again , try just removing the neg cable and see if it dies again
jim
Mar 11, 2007 at 9:44 AM
CAVALIERDRIVER65
  • 31 POSTS
[quote:e5427f976f="CHEVYII"]where does the neg cable go , have you checked that yet , make sure it is still on the eng and not broken or corroded , if you have to jump it again , try just removing the neg cable and see if it dies again
jim[/quote:e5427f976f]
ok, i'm going up to my car today. (its parked at a garage now) so ill hoist it up and check where the cable goes. thanks so much for your help and ill get back to you if nothing occurs.
Mar 11, 2007 at 9:47 AM
CHEVY22
  • 1,375 POSTS
let me know either way
Jim
Mar 11, 2007 at 9:59 AM
CAVALIERDRIVER65
  • 31 POSTS
[quote:aeeae22f7b="CHEVYII"]let me know either way
Jim[/quote:aeeae22f7b]
Also, I was wondering how to make my horn work again. There is no fuse in the box for the horn and i wan wondering how to get this fixed.
Mar 11, 2007 at 10:52 AM
CHEVY22
  • 1,375 POSTS
put a fuse in it and see what happens , my guess is someone may have had a problem with the horn and pulled the fuse , maybe it kept blowing the fuse , any luck with your other issue ?? i would stick to that right now , get ya on the road first then we can tackle the horn
jim
Mar 11, 2007 at 10:55 AM
CAVALIERDRIVER65
  • 31 POSTS
[quote:80f0974fff="CHEVYII"]put a fuse in it and see what happens , my guess is someone may have had a problem with the horn and pulled the fuse , maybe it kept blowing the fuse , any luck with your other issue ?? i would stick to that right now , get ya on the road first then we can tackle the horn
jim[/quote:80f0974fff]
Ok ill fix the charging issue first. Thanks for your help and i will get back to you.
Mar 11, 2007 at 10:57 AM
CAVALIERDRIVER65
  • 31 POSTS
[quote:f1ad0388c9="CavalierDriver65"][quote:f1ad0388c9="CHEVYII"]put a fuse in it and see what happens , my guess is someone may have had a problem with the horn and pulled the fuse , maybe it kept blowing the fuse , any luck with your other issue ?? i would stick to that right now , get ya on the road first then we can tackle the horn
jim[/quote:f1ad0388c9]
Ok ill fix the charging issue first. Thanks for your help and i will get back to you.[/quote:f1ad0388c9]
Well i went to the garage to check the negative terminal cable, and i wasn't able to see underneath the car due to snow. I was able to get a booster pack and fire up the car. I went to start the car up and it worked fine but the absolute minute i took the negative booster off, the car died. I hope that was enough info for now until i can get more
Mar 11, 2007 at 5:37 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:7ac56e011f="CavalierDriver65"][quote:7ac56e011f="CavalierDriver65"][quote:7ac56e011f="CHEVYII"]put a fuse in it and see what happens , my guess is someone may have had a problem with the horn and pulled the fuse , maybe it kept blowing the fuse , any luck with your other issue ?? i would stick to that right now , get ya on the road first then we can tackle the horn
jim[/quote:7ac56e011f]
Ok ill fix the charging issue first. Thanks for your help and i will get back to you.[/quote:7ac56e011f]
Well i went to the garage to check the negative terminal cable, and i wasn't able to see underneath the car due to snow. I was able to get a booster pack and fire up the car. I went to start the car up and it worked fine but the absolute minute i took the negative booster off, the car died. I hope that was enough info for now until i can get more[/quote:7ac56e011f]
Hi. Me again, i realized already that my alternator was burnt out, but that scrap guy at the garage says that there might be a problem with the ignition system that may cause the alternator to burn out. Could he be right?
Mar 12, 2007 at 9:28 PM
CHEVY22
  • 1,375 POSTS
scrap guy , did you get the alternator used ??
Mar 12, 2007 at 10:32 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:729bcc1cc6="CHEVYII"]scrap guy , did you get the alternator used ??[/quote:729bcc1cc6]
well sort of, there was another cavalier in the field for scrap where i pulled the alternator from and i have another alternator to put in that i pulled from a 1990 gmc safari.
Mar 12, 2007 at 10:34 PM
CHEVY22
  • 1,375 POSTS
the used parts will have you chasing your tail , can you afford a reman, they should be cheap and you have a warranty
Jim
Mar 12, 2007 at 10:37 PM
CAVALIERDRIVER65
  • 31 POSTS
[quote:52b11acf95="CHEVYII"]the used parts will have you chasing your tail , can you afford a reman, they should be cheap and you have a warranty
Jim[/quote:52b11acf95]
Don't Worry about the charging problem anymore. i got rid of the cavalier and i now have a 1991 chevrolet Blazer 4X4
Mar 14, 2007 at 8:46 PM
