ignition key tumbler switch?
1990 CHEVROLET TRUCK
300,300 MILES • V8 • 2WD • AUTOMATIC
i am trying to change out my ignition switch(key &tumblers) how do I get it out?
May 24, 2009 at 2:00 PM
JDL
  • 16,098 POSTS
Here are the instructions in the diagrams below to show you how on your car. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
May 24, 2009 at 2:13 PM
MANUAL06
need to replace ignition switch on my 89 chevy truck i broke my key off in it and i need a need a new one.
Sep 11, 2020 at 12:17 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Ignition lock cylinder needs removed. To do so, perform following operations.
Remove the steering wheel.
Remove the turn signal switch. It is not necessary to completely remove the switch from the column. Pull the switch rearward far enough to slip it over the end of the shaft, but do not pull the harness out of the column.
Turn the lock to Run.
If necessary, remove the ignition key.
If equipped, remove the buzzer switch assembly.
Remove the lock retaining screw and remove the lock cylinder.
Rotate the key to the stop while holding onto the cylinder.
Push the lock all the way in.
Install the screw. Tighten the screw to 40 inch lbs. (5 Nm) for regular columns, 22 inch lbs. (2.5 Nm) for tilt columns.
Install the turn signal switch and the steering wheel.
Thanks for using 2CarPros
BOWTIE BABY
  • 101 POSTS
He is correct but he is talking about the ignition switch, you are talking about the ignition lock cylinder. You will have to disassemble part of the steering column. If you don't have a gm lock plate remover you will want to rent 1. If you need instructions on how to do it let me know and i will walk you through it.
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry about that, I edited above post to removing lock clyinder, not switch. Thanks Bowtie Baby.
Thanks for using 2CarPros.com!
KSCARSDALE
Electrical problem
1976 Chevy Truck V8 Two Wheel Drive Automatic
how do i change an ignition lock cylinder in a 1976 chevy pick up i am experienced in repairs i have the steering wheel off and all the horn and blinker stuff out of the way but i cant find the release pin to remove the lock cylinder.
BOWTIE BABY
  • 101 POSTS
No problem, I worked in parts for a long time and many people mistake the two of them. Good luck, let me know if you need more info. The car pro guy is correct but he left out the lock plate removal, you have to compress the plate and spring then remove the retaining clip.
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Remove steering wheel and turn signal switch.
It is not necessary to completely remove the turn signal switch. Pull the switch over the end of the shaft; no further.
Place lock cylinder in RUN position.
Do not remove the ignition key buzzer.
Insert a small drift pin into the turn signal housing slot. Keeping the drift pin to the right side of the slot, break the housing flash loose and depress the spring latch at the lower end of the lock cylinder. Remove the lock cylinder.
WARNING
Considerable force may be necessary to break this casting flash, but be careful not to damage any other parts. When ordering a new lock cylinder, specify a cylinder assembly. This will save assembling the cylinder, washer, sleeve and adapter.
INSTALLATION:
Hold the lock cylinder sleeve and rotate the knob clockwise against the stop.
Insert the cylinder into the housing, aligning the key and keyway.
Hold a 0.070 in. drill between the lock bezel and housing. Rotate the cylinder counterclockwise, maintaining a light pressure until the drive section of the cylinder mates with the sector.
Push in until the snapring pops into the grooves. Remove drill. Check cylinder operation.
The drill prevents forcing the lock cylinder inward beyond its normal position. The buzzer switch and spring latch can hold the lock cylinder in too far. Complete disassembly of the upper bearing housing is necessary to release an improperly installed lock cylinder.
GUMMERE
The electrical system is dead. The battery is good but there is no power. No lights, horn, heater motor or starter. Sometimes it will just start working for no reason. I replaced the ignition switch a few months ago. Any ideas on how to track this down?
HMAC300
  • 48,601 POSTS
first has it been modified? if so look for burnt fusible links normally around starter. then start by checking to see if junction box going through firewall is connected and not burnt up due to age. check wires leading behind motor on passenger side not being caught or bunt up from manifold and or pinched between trans/block. check ground from battery to body and body to engine shold be one from valve cover to body pass side or block to firewall
CJ MEDEVAC
  • 11,004 POSTS
Hmac300,
I'M GOING WITH THE SUPER EZ STUFF!
STUFF THAT IS TAKEN FOR GRANTED
SEE MY "OLE RELIABLE" ANSWER IN THE POST OF THE PAST (KEEPS ME FROM PECKING IT OUT ALL OVER AGAIN)
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
I MADE A FEW PICS AT THE END OF IT TOO!
Gummere, RETURN BACK HERE WITH SOME GOOD NEWS!
THE MEDIC
GUMMERE
Thanks for the tip.
As far as I know it has not been modified. I figured it must be a bad ground. So I checked the ground from body to engine and engine to frame. I even clipped a jumper cable from block to body and battery to engine - nothing.
I did check the hot wire coming off the starter going to the fuse panel and it has been burnt and is bare in several places (that will get fixed soon). I checked the fuse panel and there is 12 volts on the back of the fuse panel. I figured it must be a bad ground.
Any other ideas would be most appreciated.
CJ MEDEVAC
  • 11,004 POSTS
WHATU WAITING ON?!
THE OLE BURNT WIRE MIGHT HAVE A BURNT CONNECTION
IN OTHER WORDS, THE CONNECTION MIGHT NOT BE MAKING CONTACT, EVEN THOUGH IT'S STILL TOGETHER DUE TO THE OVERHEATING
OR THE BAD/ INTERMITTENT CONNECTION MAY HAVE CAUSED THE WIRE TO OVERHEAT AND COOK THE INSULATION, MAYBE THE WIRE IS IN HALF INSIDE THE INSULATION
THIS IS WHERE YOU TAKE THE CONNECTIONS APART, REPLACE DAMAGED STUFF, OR SAND THE CONNECTORS SO THEY MAKE GOOD CONTACT AGAIN.
WHILE TESTING, YOU MIGHT LOOSEN THE CONNECTION(S) A LITTLE BIT AND "SCOOCH" THE RINGS/ FORK/ ETC AROUND A LITTLE BIT, IN HOPES THAT IT WILL MAKE CONTACT (FOR A SECOND OR TWO ANYWAY) SO YOU WILL KNOW YOU HAVE FOUND THE "PROBLEM CHILD"!
THE MEDIC
