[b:49470b89d7]the truck wont start right away you can crank it over for about a minute then as sooon as the oil gauge shows pressure you cab look in the throttle body and then it feeds fuel starts and runs fine and will restart right up unless you let it set for a while .
I changed the oil pressure sending unit, fuel filter etc. no change need help//thanks Bill[/b:49470b89d7]
Dec 29, 2006 at 6:10 PM
