1989 Chevy Truck Timing Gears
1989 CHEVROLET TRUCK
174,000 MILES • 6 CYL • 2WD • AUTOMATIC
MGG2165
I am having to replace the Timing Cover, Chain and both gears. I pulled everythig of and with out moving the cam shaft or crankshaft put the new chain and gears back on. I noticed that on the gears there are on both gears 2 small counter sunk holes are they supposed to line up? I am at the point where I am puttong on the Timing Cover and thats when I noticed this.
Mar 5, 2008 at 4:29 PM
M8TRIX01
  • 36 POSTS
Yes they should line up the cam gear the notch on the bottom and the crank gear the notch on top ...
Mar 5, 2008 at 4:32 PM
MASTERTECHTIM
  • 4,750 POSTS
yes i believe they are. have you rotated engine and see if they line up? they will line up on top dead center at 0 degress.
Mar 5, 2008 at 4:34 PM
