1988 Chevy Truck timing not right
1988 CHEVROLET TRUCK
157,888 MILES • 6 CYL • 2WD • AUTOMATIC
CHEVY 1
when checking timing per emission sticker timing will not go to base timing?base timing should be zero but cant check?i've had some running issues and codes.replacement of these parts were nessary.coolant temp sensor for computer,egr diaphram leaking,tstat sticking over heating,catalytic converter blockage.truck runs and idles but after a short distance dies,[like if flooding condition].turns right back on and will not repeat problem until truck cools.code 42 pops up which is normal because truck dies cutting off signal to computer no help.thanks for the help.
Oct 30, 2009 at 9:14 PM
When you check the ignition timing the EST wire must be disconnected.
Oct 30, 2009 at 10:31 PM
CHEVY 1
wire is disconnected per sticker and will not return to base timing computer advance wont cancel?
updated:
wire was disconnected and timing will not return to base ,dist moves, advance and retard, but computer advance wil not disingage per wire disconnect?
Oct 31, 2009 at 7:07 PM
Check the EST wire back to the computer also test the knock sensor-
Nov 2, 2009 at 4:46 PM
