1988 Chevy Truck tail lights don't work
1988 CHEVROLET TRUCK
250,000 MILES • V8 • 4WD • AUTOMATIC
WINEDOTMIKE
i recently reran an antenna cable through my dash. afterwords my tail lights quit. i've checked them with a tester & i have power all the way to the bulbs(which are good), but no lights. i'm thinking there is a ground problem. is there a ground wire for the rear tail lights under the dash? my license plate lights work. i have a shell with a 3rd brake light spliced into the drivers side tail light harness, both the ground wire & hot wire light the tester, it has to be a ground problem, but where? i have to have disturbed it under the dash somewhere, any clues as to where it could be? thanks in advance
Mar 2, 2008 at 12:52 PM
Re-route the ground wire if it has a black wire otherwise wrap a wire around the socket and find a good ground and try this whether it'll work-
Note: the info I have is that the bulb socket is the ground-
Mar 3, 2008 at 9:50 AM
