Engine Mechanical problem
1988 Chevy Truck 6 cyl Four Wheel Drive Manual 186XXX miles
I asked this question before but never got a real answer. I have a problem with my oil pressure. The truck sat for about 2 months and when i went to run it again this is what it does; at start up everything works fine, my oil pressure climbs to about normal levels then after 10-30 seconds the gauge drops to zero and the "check gauge" light comes on.
I have replaced both the oil pump and the sending unit. I primed the new pump through the distributer with a full quart of oil. there is also a ticking noise which seems to be from the bottom end. After all that, there is no change in behavior. Do you have any suggestions?
Thanks,
Scott Henrie
Thanks,
Scott Henrie
Feb 26, 2008 at 5:43 PM
