1988 Chevy Truck ignition timing?
1988 CHEVROLET TRUCK
140,000 MILES • V8 • 4WD • AUTOMATIC
SPURADIK
I installed a new 5.7L 350 engine in my truck. I didn't have a timing light handy when I went to set the timing. I used the same distributor from my old engine and adjusted it by the idle sound. It sounds good and everything, but the idle picks up and bogs down... I even put a timing light on it and adjusted it the way it was supposed to be. Wow it idles great now, but now when I drive and push on the gas I loose all power and my check engine light comes on. Could this be that I need a new distributor? I ended up adjusting the timing back by sound because I could not drive with it set with a light.
Feb 15, 2009 at 7:01 PM
Pull the code/s from the computer and comeback with it this is where we start
Feb 15, 2009 at 7:07 PM
SPURADIK
i guess ill have to try when i get back to my truck in a couple weeks.
Feb 15, 2009 at 7:17 PM
