1988 Chevy Truck cold starting
1988 CHEVROLET TRUCK
192,000 MILES • V8 • 2WD • AUTOMATIC
BOBCUNN
first start of day engine stumbles for about 2 to 5 seconds and then quits and after 7 or 8 of the same type of attempts (also will not throttle up on any of the attempts). Then the engine starts, Idles and accelerates normally. I have replaced o2 sensor, throttle positioning sensor, idle air solenoid, wires and plugs and cap changed about 5000 mi ago. This happens most often when the truck sits for more than 12 hours or so.
Oct 22, 2009 at 7:19 AM
JDL
  • 16,098 POSTS
Welcome to the site, after it sits overnight, I'd use a fuel pressure gage . Check fuel pressure, key on engine off. Your fuel injected? Any codes?
Oct 22, 2009 at 3:59 PM
