1988 Chevrolet 1500 Series 1/2 Ton Pick-up 2WD - Battery not getting proper charge from the alternator. The alternator is putting out 14V, but when you test the charging system, it only reads 11V. When you unhook the positive battery cable while the truck is running, sometimes the truck will run, sometimes it will cut off. If you check the voltage when you unhook the positive cable from the battery, it shows 14V.
I have:
tested and replaced alternators
replaced battery
changed starter
traced wires - doesn't seem to be a short
I am wondering if there might be a short in the steering column because the ignition switch has a lot of play in it and when you put on the turn signal, the amp meter fluctuates. This problem goes and comes and sometimes it does fine, while other times the truck idles like it is going to cut off.
Any ideas as to what I can also try
I have:
replaced battery
changed starter
Jul 13, 2009 at 3:14 PM
