1988 Chevy Celebrity Volts Light On After Jump Start
1988 CHEVROLET TRUCK
JOANBP
Hi there,
The mileage on this car is just under 104,000.
The car had been starting up and running fine until the other morning. My husband went to start it and it was dead. The car was jump started and seemed okay. It was left running unattended for a few minutes and it stalled and would not restart. We think that the volts light on the instrument panel went on after the first jump. We tried jump starting it again but had no luck. Today we replaced the battery and the car starts and runs fine... so far. The volts light is still on.
The Owner's Manual talks about the voltmeter but that isn't part of the instrument panel in this car. Can you please tell us what this light indicates?
Thanks in advance for your help. :roll:
Jan 13, 2007 at 3:39 PM
BOOTDOG
  • 665 POSTS
that light you're talking about is telling you that the alternator is not charging. if you can take the vehicle to advance auto and they will check your charging system for free. a good alternator will keep a charge on the battery, which it should be charging around 14 to 14.5 volts while running. i'm sure that you have a bad alternator. good luck :)
Jan 13, 2007 at 3:47 PM
BACKYARDMECHANIC
  • 337 POSTS
The light is on because there is more than likely a problem with the charging system. This is probably the reason the car would not start in the first place. First check the alternator belt to make sure it is tight and not slipping. A simple and quick way to check this is to see if you can turn the alternator by hand . If you can then the belt is slipping and you need to adjust it if you can. To check if the alternator is charging the system proper you will need a voltmeter. Connect the meter to the batery ( + of the meter to + of the battery and - to -) And observe the reading. If the alternator is working properly then the reading should be around 13.2 to 15.2 volts with the car running. I also like to test the alternator under a load by turning all the accessories on like the lights fan defroster etc. Even with everything on the voltage should not drop below the minimum. :) Hope this helps
Jan 13, 2007 at 3:57 PM
