Fuse Block Under left side of dashboard. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
May 21, 2008 at 4:23 AM
CHRISTINERANKIN
MEMBER
1 POST
I hooked the battery up backwords and I cannot find the
the fusible link or could it be something else?
Oct 20, 2018 at 6:22 PM
(Merged)
HMAC300
CERTIFIED EXPERT
the fusible links run off the starter.also if you have a junction box near battery on firewall or fender-well. see picture.
Image (Click to enlarge)
(Merged)
PAT5196
MEMBER
Does not show where the conversion van fuse box is?
Nov 19, 2020 at 9:36 AM
STEVE W.
CERTIFIED EXPERT
PAT5196, would you please use this link and ask this as a new question. Please include all the information you can including which company did the conversion as conversions normally do not use the OEM wiring other than the up-fitters connection. https://www.2carpros.com/questions/new
