1986 Chevy Truck V8 Two Wheel Drive
I am trying to get an '86 truck with a 350 running. Replaced all parts in the HEI distributor. The rotor doesn't turn when the engine is manually turned. The timing chain and gears are fine.
This truck ran when I brought it home and it sounded great. No odd noises whatsoever. The gears on the end of the rotor shaft are intact.
What should I check next?
Aug 22, 2010 at 6:33 PM
