I have tested the socket for my left rear turn signal/break light/running lights "1157 bulb". The bulb itself is good, i read 12volts to ground on brown wire "running light" and intermittent signal on the yellow wire. I assume there is a short in the line from somewhere from the steering column to the socket. I have stripped wire bare and tested just outside the socket to make sure it wasn't the socket itself. Any suggestions to where i should concentrate?
Aug 15, 2010 at 10:03 AM
