1981 Chevy Truck carb
1981 CHEVROLET TRUCK
CHRISFORD24
Engine Mechanical problem
1981 Chevy Truck V8 Two Wheel Drive Automatic
the carb in my truck always gums up and sticks on high idle and it also doesn't ahve a fuel filter. Not having a fuel filter would that cause my issue?
Nov 15, 2008 at 11:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Very possible. Why doesn't have fuel filter?
Nov 15, 2008 at 11:37 PM
ACTIONPACK
  • 4 POSTS
should be a fuel filter at carb , follow fuel line to carb and there at carb where fuel line is there should be a bigger nut behind the fuel line nut , first remove fuel line and then remove bigger nut and fuel filter will be inside , this is if u have carb and mechenical fuel pump , and the high idle my be do to the linkage on the outside of carb , try some carb cleaner around these areas ,
Nov 16, 2008 at 2:31 PM
