The pull switch for the headlights is not working. The headlights don't come on and the cab light won't turn on either. The floor switch does not turn on the high beams either, but maybe the pull switch is bad. Would this cause the problem and if so how do I replace it? Would the floor switch being bad cause the cab light to not turn on? Thanks
Well I replaced the dimmer switch and the headlight switch and still no lights. I was looking for the headlight fuse or relay and can't find it. Anymore ideas. Thanks
Apr 16, 2010 at 3:51 PM
