Transmission problem
1979 Chevy Truck V8 Four Wheel Drive Manual 37894+ miles
I recently did an engine swap and put a 350 out of an '85 K5 Blazer into my truck. I am wanting to put the original SM465 tranny back into my truck. But where I am running into a problem is finding a flywheel that has the same bolt pattern as the crank.
Right now, the engine that I am putting in has a very small grouping and bolt pattern for the flywheel. It was originally hooked up to an automatic and had a flex plate. I cannot find a flywheel with that small of a pattern to install. Do I have to change out the crank to one that has the manual flywheel pattern attached to it or is there something else I can do?
Jul 4, 2010 at 7:10 AM
