Electrical problem
1966 Chevy Truck 6 cyl Two Wheel Drive Automatic 156K miles
My son has inherited my fathers c10. It sat for three years after he restored it and now we have replaced bulbs and shook out the cobwebs BUT the back up lights do not work with or w/o the headlamps on, the tail lamps do not come on with headlamps, the brakes lights do not work while headlamps are on but will work without headlamps on. The tag light does come on with the headlamps. The dome light does work. The only other thing that is strange is that the wipers will stop in the "up" position (I don't remember that ever happening before/not sure if that is normal) once they are turned off. If I turn them off while in the off position, they will return to stop in the up position if I hit a bump. Also the front running lights in the hood come on with the headlamp switch pulled half way out and go off when the switch is all the way out and the headlamps turn on. The horn is not hooked up at the fuse box but is wired otherwise. No radio hooked up and I can't think of anything else to add other than the gauges work. Please help, we are lost.
Aug 5, 2010 at 10:28 PM
