1964 Chevy Truck specs
1964 CHEVROLET TRUCK
164,000 MILES • 6 CYL • 2WD • MANUAL
DJOEL
I have a question on engine specs. I have a 292 L6 torn down to the block and have new main bearings and rod bearings i would like to install. I was just wondering what the torque on the main caps, rod caps, head bolts, crank thrust, and vibration dampener should be. Thank you.
DuWayne
Oct 3, 2009 at 11:09 PM
DR LOOT
  • 2,311 POSTS
torque Specifications are on the main caps 60-70 ft lbs., rod caps 30-35, head bolts 85-100, crank thrust .007-.016, and vibration dampener is a Pressed on, just make sure you lubricated, so you don't strip out the bolt, and it presses on easier.
Oct 6, 2009 at 10:10 AM
