1961 Chevy Truck throw out bearing replacement
1961 CHEVROLET TRUCK
RANDY SCOTT WICOFF
Transmission problem
1961 Chevy Truck 6 cyl Two Wheel Drive Manual
Is it difficult to replace the throw out bearing or do I need more repairs?
Dec 12, 2009 at 12:54 PM
DR LOOT
  • 2,311 POSTS
You will have to remove the transmission, my advice to you is, if you going to chance to throw out bearing you you better inspect the clutch plate also, because the truck is old. Have you inspected the linkage to the to the clutch, make sure you have no play in the bushings,
Dec 13, 2009 at 11:49 AM
