99 blazer transfer case stuck in neutral??
1999 CHEVROLET TRAILBLAZER
ADMELIN
I have a 99 blazer 4x4 w/4.3 litre auto w/overdrive and electric shift for the 4x4 w/4button control in dash. I can shift the transmission and it seems to be shifting as I can feel it start to turn and when returning the lever to park the pin will grind into park if I don't shut the vehicle off. I have no forward or reverse no matter where I select the controller switch for the 4x4. In park I still have to block the wheels or it will roll downhill. I can press the buttons for the 4x4 and here nothing shifting, no lights come on at the buttons. Can anyone help, I see lots of posts with problems shifting from one range to another but still can drive it, I have no movement at all?? No hard driving been done, working fine then backed up 15 feet and lost all functionallity. HELP. Mileage 180,000 km.
May 23, 2007 at 6:27 PM
ADMELIN
Just a blown fuse on the ATC. Kept blowing them till shift solenoid made full fotation back to 2WD.
Assume that the shift solenoid is gummed up from lack of use. Will try to shift a couple times, if this doesnt free it up will take apart and clean.
Jun 2, 2007 at 1:13 PM
