94 blazer oooops
1994 CHEVROLET TRAILBLAZER
BITSEY
We loaned our 94 blazer to our room mate to go to jury duty. It was a very cold foggy morning. She got about 15 miles down the freeway and it started lurching and smoking. We called the tow truck and had it brought home. We found that instead of turning off the rear window defroster she had hit the low 4 wheel drive button. She said she was going 65 mph when she decided she needed to pull it over. I am amazed that it could go 65 in low 4 and drive. She said it wouldn't go any faster than that. It looks like the fluid came out the vent up in the engjine compartment. The back end is coated from it blowing back. Do you think it is ruined, or should we try adding fluid and see what happens. It still moves in 2 wheel drive with no noises. We are really hoping it is not ruined. She feels really bad. Your input will be much appreciated.
Jan 25, 2006 at 12:54 PM
SC1 RACING
  • 117 POSTS
did it blow engine oil or trans fluid out? if it was engine i would change oil and filter start it up and check for noises.
65 mph in 4 wheel low is around 5 grand on the tach. stock will hold that as long as it wasnt hot, or out of oil.
Jan 25, 2006 at 1:22 PM
