92 S-10 Blazer Engine Lopes At Idle
1992 CHEVROLET TRAILBLAZER
5PT0ETR
I Have a 92 S-10 Blazer and the Engine Lopes At Idle
I have replaced a lot of parts like injectors, fuel pump
Fuel filter, map sensor, spark plugs, wires, cap rotor,
Distributor, O2 sensor, coil, tps, and I have check the
Egr valve and for vacuum leaks what else can cause
This
Scott
Jun 12, 2006 at 6:16 PM
SYNCRAIT
  • 235 POSTS
does it do it all the time or just at low rpms.... have you checked your compression and timing? good luck :)
Jun 17, 2006 at 6:47 PM
