86 Blazer heater resistor
1986 CHEVROLET TRAILBLAZER
TBJ
I have an 86 full size Blazer 140,000 miles with a 350 that I have to keep changeing the resistor for the heater. after about a month when you turn it on it only works on high after you tap on the heater solinoid. After replacing the resistor it works fine
Feb 16, 2007 at 12:39 PM
CHEVY22
  • 1,375 POSTS
hi
i would check the wiring to the resistor, fan and switch for shorts , there is a problem there somewhere causing the resistor to fail
jim
Feb 17, 2007 at 12:36 AM
CHEVY22
  • 1,375 POSTS
could be but the best thing to do is check resistance on both this will tell you where you stand ,
Feb 23, 2007 at 5:33 AM
