2004 Chevy Trailblazer power steering
2004 CHEVROLET TRAILBLAZER
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
JRPLUMR
my power steering went when i was driving. the belt is good and fluid level is good any ideas
Jan 10, 2009 at 12:18 PM
MMPRINCE4000
  • 8,548 POSTS
If belt is good and there are no leaks, then a seal in the pump is more than likely bad, and the pump will have to be replaced.
I believe a reputable shop can disconnect the pressure line from pump, install gauge and measure hydraulic pressure. If low, then pump, if normal then rack.
Jan 11, 2009 at 7:48 AM
