2004 Chevy Trailblazer engine won't idle and stalls when a/
2004 CHEVROLET TRAILBLAZER
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIGA46
When turn on a/c rpm's go from about 900 to 400, then engine stalls out after, after a few seconds, also with a/c on when come to a stop rpm's won't idle and engine stalls
Sep 5, 2009 at 12:31 AM
NEVERBUYACHEVY
  • 9 POSTS
I've been fighting the same problem for the last year plus. In time you will likely get a trouble code setting off the check engine/service engine soon light. The trouble code will be for the cam shaft position sensor and the crankshaft position sensor. I was Unfortunate enough to bring it to the wrong dealer for the first 3 tries to fix the problem and got ripped off. With research on line and talking with several mechanics I was told and found out one sensor will set off the other and both will need to be replaced. They are not too expensive, 80 U.S. dollars for the two parts. After the sensors are changed the PCM will need to "relearn" the timing of the engine. This almost has to be done at a GM dealer, and cost about 80 U.S. dollars. Total time to replace both sensors should be 1/2 hour. The cam shaft sensor is very easy to change, the crank shaft sensor is a bear to get at. I choose to change the cam sensor myself, but couldn't reach the crank sensor. Change both sensors and have GOOD DEALER relearn the computer system. Mine seems to be working for now, best of luck.
Jun 15, 2011 at 8:19 PM
