2004 Chevy Trailblazer Code P0496
2004 CHEVROLET TRAILBLAZER
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
TRICIA557
I got code P0496 which part should I change?
Nov 7, 2009 at 11:44 PM
HMAC300
  • 48,601 POSTS
that is the evap purge canister . try tightening your gas cap 3 clicks after tight and clear the code and that should help. If you don't tighten the gas cap it sets a code......
Nov 18, 2009 at 6:25 PM
TRICIA557
I did what you said and the check engine light came back on.
Dec 8, 2009 at 6:59 PM
HMAC300
  • 48,601 POSTS
sometimes the cannister purge sticks and if you give it a light smack with a screwdriver handle it let's it close an dwork properly.. the valve is inside the frame about the middle of the truck by the gas tank. Actaully have a pro look at it though as if it has to be changed, he'll know how much it costs....
Dec 11, 2009 at 8:28 PM
