2004 Chevy Trailblazer Brake Lights
2004 CHEVROLET TRAILBLAZER
67,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIM FOREMOST
The two lower brake lights in the rear don't work, while the third, higher brake light does work. The bulbs are OK because they come on when I turn on the emergency flasher. I also changed fuse #34 in the fuse box under the rear seat and they still don't work.
Does anybody have any idea what might be wrong?
Nov 5, 2009 at 1:45 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the brake light switch, located under driver dash on brake pedal bracket. the high-mount brake lamp is on a different circuit then the brake switch.
Nov 5, 2009 at 2:46 PM
