xTooltipElement
Service Information
2004 Chevrolet TrailBlazer - 4WD | Bravada, Envoy, Rainier, TrailBlazer (VIN S/T) Service Manual | HVAC | HVAC Systems - Automatic | Diagnostic Information and Procedures | Document ID: 633824
Actuator Recalibration (Primary)
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
Place the ignition switch to the OFF position.
Disconnect the scan tool.
Install the HVAC control module.
Connect all previously disconnected components.
Start the vehicle.
Wait 40 seconds for the HVAC control module to self-calibrate.
Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted improper HVAC performance will result.
Preferred Method (w/ Scan Tool)
Clear all DTCs.
Place the ignition switch in the OFF position.
Install the HVAC actuator.
Start the vehicle.
With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
Clear all DTCs.
Remove the HVAC B fuse for a minimum of 10 seconds.
Install the HVAC B fuse.
Start the vehicle.
© 2008 General Motors Corporation. All rights reserved.
Nov 7, 2008 at 1:56 PM
