2002 Chevy Trailblazer Wheel Hub
2002 CHEVROLET TRAILBLAZER
MVIEIRA
Tires and Wheels problem
2002 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic
What size is the nut on a 2002 Trailblazer wheel hub
Oct 29, 2008 at 6:03 AM
RACEFAN966
  • 5,029 POSTS
I am assuming that you are refering to the nut in the center that keeps the axle tight? If so that should be a 36mm. It will need to be a deep socket 6pt prefered and impact type. Hope this helps
Oct 29, 2008 at 10:14 AM
MVIEIRA
Yes, I was refering to the nut on the Axle that holds the Hub on. Thank you very much for the info.
Mike V.
Oct 29, 2008 at 12:01 PM
RACEFAN966
  • 5,029 POSTS
Great glad I could help. No don't forget to make sure that if you have ABS that you run the wire from the hub as the old one was ok. If you need anymore help just ask. Thanks for the support.
Oct 30, 2008 at 10:43 AM
