2002 Chevy Trailblazer oil pressure gauge
2002 CHEVROLET TRAILBLAZER
102,000 MILES • 6 CYL • 4WD • AUTOMATIC
JORKEITH
When driving during acceleration or idling the check gauges light displays and the oil pressure gauge dives to 0 pressure for a few seconds then fluctuates back to the proper reading as the check guages light goes back out and now it's a bit more routine than when it initially started approx. 2 weeks ago. What do you feel could be the problem and the solution to repairing the problem?
Feb 12, 2010 at 10:58 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check oil pressure switch on right side engine block. See if any oil leaking and terminal tight. If good either replace switch and/or place a mechanical gague and get reading on pressure.
Hope this helps
Thanks for donate
Feb 12, 2010 at 12:30 PM
