2002 Blazer driver door air leak
2002 CHEVROLET TRAILBLAZER
RCOMBS1017
I have a 2002 Blazer and the driver's door has wind noise near the top front of it. The door does not appear to be loose. When you close it it, it lifts up a little as it latches. Adjusting the latch did nothing to help. :(
Jan 27, 2007 at 10:48 AM
MOFAH
I had a 2000 blazer. Had the same air leak. Problem was the door hing pin. Inspect your upper door hing area an d you may find the hinge pin rusted and the bushings worn. The worn bushings are causing the door to sag and hence not sealing causing the air noise :D
Mar 3, 2007 at 10:54 AM
