1999 Blazer
1999 CHEVROLET TRAILBLAZER
IZECOLD
My 1999 Blazer is making the turn signal noise continuously. It won't turn off unless you press on the brake pedal. The turn signal and hazards work pervect but that anoying noise stays on all the time. What could be the problem?
Apr 15, 2006 at 3:00 PM
LOSONE
  • 1,616 POSTS
If the noise is from the flasher units then the turn signals or flasher can't work perfectly. It sounds like you need to replace one or both flashers, They are cheap and worth a try.
Apr 15, 2006 at 5:52 PM
IZECOLD
[quote:81d15e968e="losone"]If the noise is from the flasher units then the turn signals or flasher can't work perfectly. It sounds like you need to replace one or both flashers, They are cheap and worth a try.[/quote:81d15e968e]
How many flasher units are in the blazer. I already replaced one and it didnt fix the problem.
Apr 17, 2006 at 5:28 PM
LOSONE
  • 1,616 POSTS
There are 2 one for the hazard flashers and one for the turn signals.
Apr 17, 2006 at 5:37 PM
