2002 Chevy Tracker Brake Pedal sticks
2002 CHEVROLET TRACKER
32,670 MILES • 4 CYL • 4WD • MANUAL
SCARFACE6303
I currently live in alaska and that is where I bought the truck a couple of years ago, about a month ago i began to notice my brake pedal would stick when I pressed down on the brakes, and as the truck is run and heats up to operating temp the pedal begins to make a noise when I press down on it, it is not a squeking noise it is more like a clunking noise, and I can feel it in the pedal. I can easily pull it up with my foot, so I had it taken in and they replaced the master cylinder, and no change. I lubed the pedal with a lubricant and still no change. any Ideas? next idea I have is the brake caliper piston.
Oct 19, 2010 at 3:27 PM
Check the brake booster and the ABS unit
Oct 19, 2010 at 4:23 PM
