Alternator?
2002 CHEVROLET TRACKER
40,000 MILES • 4 CYL • 4WD • AUTOMATIC
JJCMP478
For the last 6 months I noticed that when I start my vehicle my head lights & dash lights brighten up after about 10 seconds & start to flicker (strobing). My alternator, battery & other connections are clean & tight. battery is charging & not giving me a problem. Is this a sign of a soon to fail alternator/regulator? As a back yard machanic I have never seen this happen...
Thanks,
John
Feb 17, 2010 at 6:48 PM
RACEFAN966
  • 5,029 POSTS
Well what I would do first is take it to your local parts store. Have them do a battery and charging system test. Let me know what they find and we will take it from there.
Feb 18, 2010 at 9:13 AM
HAMMER15
We replaced the alternator and know the belt is starting to tear. Do the pulleys on the alternator have a standard number of ribs, we think the pulley has 4 and the rest of our car has three. Would this cause the belt to break, or did we put the belt on wrong?
Nov 13, 2019 at 12:02 PM (Merged)
HMAC300
  • 48,601 POSTS
torn belts can be for m misalignment, like a spacer missing from alternator, incorrect pulley (ribs). Normally you use the old pulley so no problems. Or oil on belt.
Nov 13, 2019 at 12:03 PM (Merged)
MSGB12000
Where are the mounting bolts located that hold the alternator in place? We are trying to replace the alternator anr have only found the top (short) mounting bolt. Any help out there?
2CARPRO JACK
  • 11,533 POSTS
Do you have the new alt? if so look at it to see where the mounting holes are.I found this pic. does it look like your alt?
https://www.2carpros.com/forum/automotive_pictures/1639_alternator_1.jpg
