Engine Performance problem
2001 Chevy Tracker 4 cyl Four Wheel Drive Automatic
My problem is, when you travel a distance,or if you have to idle in a drive-thur and then go to take off it will start to miss and quit. It is very hard to get back started,if you keep trying it will backfire thur the air filter and stink, then if you get it to start it will miss and sputer and slowly start to run right. If you have the time you can let it sit for about 20 minutes and it will start back fine. We have done replaced the starter and the o2 sensor. I hope you can help me.Thank you for your time.
Mar 28, 2009 at 8:22 PM
