1999 Chevy Tracker Vehicle is hesitating...
1999 CHEVROLET TRACKER
101,600 MILES • 4 CYL • 4WD • AUTOMATIC
LBRADLEY3912
For the past couple of weeks I have been experiencing some hesitation with my 1999 Chevrolet Tracker when trying to accelerate after stopping for a red light or at a stop sign. Just prior to this my vehicle quit on me when trying to back out of my driveway. I had the spark plugs changed and a new fuel filter put on and it has not quit again, but now there is occasional hesitation and a sputtering sound. The other day I had the a/c running and when I came to a stop sign it more than hesitated, it felt like it was about to quit. So I punched the gas and it kept going. I came to another stop sign about 30 feet away and it did it again. I turned the a/c off and when I stopped at a red light about another 30 feet away it didn't hesitate at all when the light changed and I accelerated. I havn't run the a/c since then, but still experience occasional hesitation. When I'm driving it rides well and doesn't have any problems except for making an occasional sputtering sound that comes and goes. Any suggestions on how to fix this problem would be greatly appreciated.
Jul 30, 2009 at 6:59 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 30, 2009 at 7:42 PM
EMZPOP
I have a 99 Tracker as well. Same problem. I first removed the Ignition Coil packs (Trackers use a coil pack on top of the spark plugs) I tightly wrapped the assembly that fits into the engine with electrical tape. Hesitation was completely eliminated. BUT, after 3 months or so, it returned. Rather than rewrapping the plug wires I replaced the packs for about $25 a piece
Oct 2, 2009 at 11:17 AM
