1999 Chevy Tracker Door panels
1999 CHEVROLET TRACKER
70,000 MILES • 4 CYL • 2WD • MANUAL
LHARV
I need to remove both door panels to access the speakers because they need replacing. I am not sure how to do this without breaking some of the attachments. Thanks for your help.
Apr 3, 2010 at 5:04 PM
Hello, to remove the door panel on any car is a unique instruction, every car is different. Most car can be done as follows: Disconnect the negative battery cable. Remove outside mirror opening cover, remove inner door handle trim cover, remove window crank if equipped, remover power window and door lock switch, gently pry door panel to disengage the retainer clips, disconnect the electrical connector and reverse to reassemble. Please let me know how it goes. Thanks for using 2carpros.com
Apr 7, 2010 at 5:16 PM
