2003 Tahoe, 55K miles, auto, 5.3L.
Rough idle when cold. smother idle once fully warmed up. Acceleration seems normal. Check engine light - DTC 0174 - system too lean bank 2. Check engine light went off for a couple of days. Check engine light - DTC 0174 came back on. Error codes reset, check engine light off with reset, added bottle of fuel injector cleaner to gas tank. All this has happened in less than 200 miles. Air temperature in the 20's - 50's F. Only DTC 0174, no 0171 code. Do I have a bad injector on side 2?
Update 12/02/2007 - thanks for all the help. The local Chevy dealer diagnosed the problem as a leaking intake manifold gasket. Cost was $500 to replace the gasket.
Ron
Ron
Nov 23, 2007 at 11:55 AM
