Replacing Pitman Arm and Idler Arm
CHEVROLET TAHOE
PASTORMIKE
1998 Tahoe 4WD 5.7L 150K miles - I was told by the dealer I needed to replace the idler arm and lower ball joints on my Tahoe. I was underneath the car most of the afternoon on Saturday trying to get the idler arm off. What's the recommended process for removing the idler arm and pitman arm. All tapered pins are holding tight and I can't get a puller in the tight quarters.
Thanks, Mike
Apr 22, 2007 at 10:01 PM
2CARPRO JACK
  • 11,533 POSTS
Does that Idler have a "stand" as well or is it one piece?If it has the stand, I prefer to do both. A tool called a "picklefork" is used to seperate the two pieces for the Idler, the Pitman arm needs a puller so as not to damage the steering box, but the picklefork can be used on the end that attaches to the center link
Apr 23, 2007 at 8:03 AM
